AutoCaD file corruption
Every time the drawing “51603691A.dwg” is opened, the panels and other objects are getting deleted, and the customer reports that he needs to copy and paste panels from DXF files “ Panel 1” & “ Panel 2”, as well as objects from the “51603691A-CM.dwg”. AutoCAD is used to create all the objects. The problem is solved by renaming the panel after copying and pasting it from the DXF and other objects files from “51603691A-CM.dwg”. I am curious to know what caused the file corruption.
