Autocad Fatal error
Autocad Fatal error
Message 1 of 8
Autocad Fatal error
Unhandled Access Violation Reading 0x0028 Exception at 4B5F4060h. Not sure what is causing the error
Replies (7)
Message 2 of 8
Alfred.NESWADBA
When do you get this exception?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 8
As soon as I launch autocad this happens it loads the overlay and then the what would usually display the files and recently opened drawings is white and the error message is this displayed.
Message 4 of 8
ennujozlagam
you can try this Disable Digital Signatures 1)On the Windows Start menu, enter acsignopt in the Search programs and files field and press Enter. 2)Clear the Validate Digital Signatures and Display Special Icons option. and see if helps. thanks
Message 5 of 8
S.Faris
Message 6 of 8
Alfred.NESWADBA
Can you please show a screenshot of that "it happens ...", I'm unsure about the "overlay"-thing 😉
- alfred -
Alfred NESWADBA
Message 7 of 8
here is the screenshot
Message 8 of 8
Alfred.NESWADBA
well, try these two options for how you can start AutoCAD:
press <WIN> and R on your keybard to get a Windows command-line.
There try one time:
"C:\Program Files\Autodesk\AutoCAD 2019\acad.exe" /NOHARDWARE
If this fails too then try this:
"C:\Program Files\Autodesk\AutoCAD 2019\acad.exe" /SAFEMODE
If both fails, then you might reset your AutoCAD profile to default as shown >>>here<<<
- alfred -
Alfred NESWADBA
