AutoCad export to DXF aama or DXF astm
Message 1 of 49
Is it possible to export AutoCAD files to DXF AAMA or DXF ASTM format?
Those formats are mainly used in fashion industry.
Thank you in advance,
Stelle
Replies (48)
Message 21 of 49
-##Just attach the dog, that will be fine
Message 22 of 49
Lee_Marable
Thanks, see attached DWG
Message 23 of 49
diego.galeano
Can you zip the DXF and then attach it ?
Modaris won't read the DWG but only the DXF.
Message 24 of 49
Lee_Marable
Good Suggestion, lets see if that works:
Message 25 of 49
Yes, lectra software will not read a dwg, but I can open the dwg and save it as a dxf to try.  It would not open by the way, I'm making changes now to make it work.
Message 26 of 49
Lee_Marable
Amazing, thanks, here it is as a zipped DXF of the file for reference.
Message 27 of 49
diego.galeano
Well I got you DXF but I'm sorry to say that Modaris won't read it.
Unfortunately I'm not and I can only help you with telling you if your file will be read properly or not by Modaris.
Message 28 of 49
Lee_Marable
Thanks Diego, I will take you up on the offer with later versions once I hear back from @dkhayes117!
Message 29 of 49
I got it to work, two small problems with your file.  Lectra is very picky when it comes to importing files.
Problem 1: I know that text is supposed to go on layer 19, but the title block is the one exception.  Put it on layer 1.
Problem 2: The title block field names should not be in all caps, ie Piece Name: not PIECE NAME:
Attached is a working, portable file.
Message 30 of 49
Lee_Marable
Fantastic, thanks so much for your help - I will use the advice you gave to work up the full patterns and maybe check again with @diego.galeano to test the files. This has been so useful!
Message 31 of 49
Lee_Marable
Hi dkhayes117,
I sent the file to my manufacturer to test if they were able to open it, but they said they unable to, and sent the attached screen shot. I have attached the .dxf that sent to them, which I am pretty sure is exactly the one you sent me, unless something has gone wrong when I zipped it to send to them...
Any ideas?!
Message 32 of 49
Not sure what is going on, but the first thing I noticed is they are trying to open a dxf in Adobe Acrobat???? Acrobat reads pdf files not dxf files! LOL
Message 33 of 49
Hello
Im trying to make a dxf for Lectra from an autocad dwg. I follow rules about layers, then I dont understand what I need to make a block .  I need Block each part ( exaple : drills)  of one patern ( example a sleeve) and then make a block with all these blocks?
Message 34 of 49
diego.galeano
Hi.
The rules for an AAMA file are very strict. Either everything is correct or the file is useless.
If you have access to both Lectra Modaris and AutoCad you could use the file that is 2 messages up from yours which is a very simple model with just one piece as an example.
To tell you what is wrong with your file the expert here is @Anonymous . Let's hope is is still around.
I do not have access to AutoCad buy I do have Lectra Modaris and I could test if your DXF file is ok or not, if that is of any help to you.
Message 35 of 49
You have two options: make all patterns into one block, or block each pattern indiviually.  If you make on block out of all the parts, this will work, but if the machine has a problem you cannot pick up where cut left off.  It will cut everything over again because it all one block. If you block each part, this will work if you give each block a unique name.  No need to block the blocks, just each part.  Also save as r12 dxf when finished.  If you have any missing lines or details in the pattern, please note that some layers can only have points or only lines on that layer, no other geometry is supported.  Make sure the part is closed as well.   Good luck.
Message 36 of 49
hello
Could you check what is wrong with these files?
Message 37 of 49
I don't see any files attached to check
Message 38 of 49
I've worked my way through this thread trying to import dxf files into Modaris.
I could not make it work with my own files, the blocks would not be visible in Modaris for import. So I moved on to use files provided by dkhays117 as a working example to determine were I got stuck.
I tried exploding the block in dkhays118's file and recreate it on layer 0.
Saved the file as dxf r12
tried to import it.
The block I created is not visible.
Any insight regarding my issue would be greatly appreciated.
Message 39 of 49
You can attach your dxf or dwg to the post and I can check it out for you.
Message 40 of 49
Thank you for taking the time dkhayes117.
The most recent try was to open your samplepiece and re-save it on my machine and software with no alterations to blocks or geometry.
It does import without errors, but it is empty. I am starting to suspect that my first problem could be related to my dxf settings.
I have tried r12 "natural" and "lines&arcs".
I have attached your original file after being saved on my machine.
Thanks again for taking the time.
