AutoCAD - ESC not deslecting objects
emacekLDT46
Message 1 of 17
emacekLDT46
I'm having a recent issue with my selections in AutoCAD. When I select something then run a command then hit ESC I expect the items to be unselected so I move onto the next thing I have to do. When I make a new selection on items I find that the other items are still selected. It's caused me a lot of grief because sometimes the items are no longer in the view and things get erased or moved without me knowing about it. I figured it out once and the fix was a command but I dont remember the command name since it was a while since it's happened. Does anybody know what the command is to deselect everything after ESC is selected?
[ The subject line of this post has been edited for clarity by @handjonathan Original: selection issue ]
Replies (16)
Message 2 of 17
imadHabash
I suggest from OPTIONS >> Selection tab >> Selection modes .. try to see if any setting needs to change.
Imad Habash
Message 3 of 17
pendean
Community Legend
Community Legend
Recent issue? As in you got a new computer, or upgraded AutoCAD, or removed/included a 3rd party add-on since then, or.... what?
How do we recreate your issue:
Which command specifically? Walk us through a scenario, step by step, so someone here can follow along.
Are the initially selected items off-screen (aka you cannot see them) when you tap ESC?
Does this happen in ALL files, or some just? Or is it totally random?
TIA
Message 4 of 17
dmfrazier
Your keyboard might be malfunctioning. Can you swap it out for another to test that hypothesis?
Message 5 of 17
TomBeauford
What command was it and was it completed when you hit escape?
Please copy & paste from the textscr the output to the command line including the command entry.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 6 of 17
Zlatislav.atanasov
I had suffered the same thing. Quick close and reopen of AutoCAD fixes the issue, at least in my end.
My personal blog - AutoCAD and AutoCAD Civil 3D hidden Secrets and great tips in one place -
https://skillamplifier.com/
Amplify your skills to a new level!
Message 7 of 17
emacekLDT46
I found the answer after a search of the web for "AutoCAD system variables with 0 or 1 or 2".
PICKADD is the culprit. For some reason it changes to a "2" which keeps the old selection set.
Now I can forget it again and ask the forum after 6 months! Good thing I have it saved.
Thanks everyone for looking into this and giving me suggestions and hopefully this will help others who want to amend their PICKADD.
Message 8 of 17
nrz13
Add PICKADD to your System Variable Monitor to be alerted the next time AutoCAD randomly changes it (and more easily change it back):
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/AutoC...
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 9 of 17
emacekLDT46
That is a great idea!
When Autodesk adds Pickadd to the list I will...lol!
Message 10 of 17
nrz13
It's not showing up for you?
Message 11 of 17
emacekLDT46
No. A ton others PICKFIRST...etc.. not PICKADD.
Message 12 of 17
nrz13
What version of AutoCAD are you using?  I'm using 2022.1.2 and the variable appears for me in SVM.
Message 13 of 17
emacekLDT46
I'm on 2021.
When Ie get 2023 it'll be on there... until then I just have to remember the command.
Message 14 of 17
TomBeauford
AutoCAD 2021 Help for PICKADD (System Variable) https://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-47C2A568-30EE-4F07-916F-884CDE25CBCA
Just enter PICKADD at the command line and set it to whatever you want but it should be set to the Initial value of 2 which is how most users prefer.
2023
Message 15 of 17
aadish_bin_abdul_sathar
thank you very much
Message 16 of 17
eugenio_gonzalez-garcia_1
Community Visitor
Community Visitor
It happen to me and pickadd is not the issue, pickadd 0 foi example will allow just select one and when click in second it will deselect the first without pressing ESC but my ESC when off deselecting without reason
Message 17 of 17
cadffm
is it always, or just partial/random?
Restart AutoCAD, run a test, does [ESC] works as expected or not?
If yes: Acad/memory issue, I can't help.
If no: What value is set to QAFLAGS
Try value 0 and test it again.
Sebastian
