autocad error aborting
I keep getting the message below when launching AutoCAD 2016 on occasion.  it keeps occurring every couple of days.
'There is a problem with the installation and autocad cannot continue.
This error may occur if the registry cleaner software has removed or altered registry keys that are required to run autocad.
To restore the required registry keys, you will need to reinstall autocad using the add/remove program functionality in the windows control panel.
I have system mechanic running on this computer but I believe I have the registry cleaner turned to off in an attempt to stop from this occurring.  I have removed the autocad 2014 version that I was running.  I never had a problem launching 2014.
Anyone else encounter this problem?
pendean
Community Legend
Community Legend
repair reinstall autocad to fix the problem usually works for most users.
