hI,
In the attached dynamic block the column portion does not remain in centre after giving .5 in distance multiplier.
Please help
Krish
Solved by vinodkl. Go to Solution.
Hello @coolkris
This issue is occurring because the column portion is included in the stretch action as well, so it not taking the distance multiplier. I have modified the block by adding another stretch parameter to stretch the column with a distance multiplier of 0.5 and a move parameter to only move the column in the plan and the dimension. Please find the drawing attached.
