AutoCAD - Driver Power State Failure
powermetalroberto
Message 1 of 12
powermetalroberto
dear, I'm desperate, I downloaded the version of autocad 2017 student, but I have podico make use of it because of several problems with the installation, whenever I try to install the program, I have a fatal mistake, a blue screen, with error DRIVER POWER STATE FAILURE, I have a computer with high specifications, can run heavy programs and video games of the highest range, after installation, when first opening, I have this very serious drawback, and not to do, or if I want to contact a person in chat support, please help me with this problem.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
A Blue SCreen is an indication you have hardware problems that need to be fixed at a computer repair shop. Do so soon.
Message 3 of 12
john.vellek
Hi @powermetalroberto,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Try this if you have an nVidia graphics card.
  • Select NVIDIA Control Panel select Manage 3d Settings
  • In the Global Settings Tab, select the Power Management Modeprefer maximum performance
John Vellek
Message 4 of 12
john.vellek
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 5 of 12
It helped me thanks!
Had problem for a week. new Asus ROG running windows 10 Lap top. Nvidia gtx 960m 4g,  AutoCAD 2017.
Its been running for over 20 mins now LOL!!!
Message 6 of 12
yes,  friend if you want to know the  easiest way to fix this error
 you can go here , i hope u will satisfied after seeing this
Message 7 of 12
hey, friend visit here to know more information how can you fix this error
Message 8 of 12
Mammoth.Engineering
Community Visitor
Community Visitor
I had the same problem and this seems to have fixed it. Thank you.
Message 9 of 12
thanks ,it works🤓
Message 10 of 12
I would like to provide solution to this issue as was very frustrated with this blue screen error. Whoever facing this issue, you just need to check first display adapter or wireless adapter. you need to be sure that driver is updated. 9 out of 10 times display drier creates this problem. especially in your case display driver could be cause of the problem.
if you need more detail you can check his link to fix driver power state failure BSOD error as i was able to resolve this frustrating issue.
Message 11 of 12
This is the best answer for the year! I had a big trouble with AutoCad for 2 weeks now so i had to reinstall windows 3 times with no result, i read so many posts but no one has mentioned this note. You are my hero, thanks a lot you saved my exam!
Message 12 of 12
17960039
Community Visitor
Community Visitor
I use Windows 11 and Fusion 360 and I have been having this issue for 3 weeks and now it's fixed with this solution. Thank you so much! I'm doing a production engineering intern at an injection molding factory and this problem was driving me crazy, now It's solved. Thank you so much!
