AutoCAD Forum
autocad dosya kaydetme sorunu
4 REPLIES 4
busracan95
541 Views, 4 Replies
busracan95
Autocad 2018 kullanıyorum.Yeni bir sayfa açıp farklı kaydet (save as) yaptığım zaman dosyayı kaydetmiyor.Nasıl kaydedebilirim?
4 REPLIES 4
imadHabash
in reply to: busracan95
imadHabash
try Ctrl+S  .
Imad Habash
try Ctrl+S  .
Imad Habash
busracan95
in reply to: imadHabash
busracan95
CTRL+S  yaptığım zaman olmuyor.Kaydetmiyor.hata veriyor.
vinodkl
vinodkl
is FILEDIA set to "0"? if yes then set it to "1"
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
imadHabash
what happened when you save your drawing ? is there a dialog appear or NOT .  you may need to check FILEDIA system variable .
Command: FILEDIA
Enter new value for FILEDIA <1>:
Imad Habash
Command: FILEDIA
Imad Habash
AutoCAD Inside the Factory
