AutoCAD Display issues
I can't use my AutoCAD because it doesn't display any object,tools, and commands. Please help me and give solution to this problem
ennujozlagam
check video
Thanks you very much sir :). it really works. But can you explain to me why do you move the command
@ennujozlagam wrote:
check video
bar?
ennujozlagam
because that is the standard location, but it's up to you where you want it to be. thanks
Why this happens? Do I need to do this all the time because it happens regularly. I only done once using this method and maybe I am just have luck that time. Can you explain this problem because I have a really hard time to do this again. thanks
P.S It is working when AutoCAD is in minimize size
ennujozlagam
When you install newly AutoCAD program, it will appear as you have it now, so you need to move to the left corner of your screen as I mentioned. You only do it once. Thanks
Another way is to save your workspace setting and can retrieve back to original customized setting.
Thank you very much.
