AutoCAD - Cursor is not aligned with UCS World
Message 1 of 13
Hello
The cursor is not aligned with the world UCS. It is at an angle.
The UCS settings and cube are set to 'world'.
Any ideas on the cause of this and how to fix it.
I have tried UCS - World - but to no avail.
Thanks.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Accepted solutions (3)
Replies (12)
Message 2 of 13
ben.saa
Autodesk Support
Autodesk Support
AutoCAD, has a system variable called SNAPANG which is used to set the snap and grid rotation angle for the current viewport relative to the current UCS. Resetting the value of SNAPANG back to 0 realigned the cross-hairs with the UCS.
Message 3 of 13
Moshe-A
@Anonymous ,
After setting ucs invoke PLAN command and hit enter twice 😀
Moshe
Message 4 of 13
No - Didn't work.
Message 5 of 13
ben.saa
Autodesk Support
Autodesk Support
Is this happening because the drawing is in a different UCS? Could you share the file?
Message 6 of 13
It worked!
I have never heard of SNAPANG before.
Thank you very much.
Message 7 of 13
ben.saa
Autodesk Support
Autodesk Support
Excellent
Sets the snap and grid rotation angle for the current viewport relative to the current UCS.
Type: Real
Saved in: Drawing
Initial value: 0.0000
When SNAPANG is set to a value other than 0, the lined grid will not display.
Message 8 of 13
zgizaraQAD37
Community Visitor
Community Visitor
WORKED FOR ME !! 👌
Message 9 of 13
Brendan_Lynch
Observer
Observer
You the MAN -:)
Message 10 of 13
Brendan_Lynch
Observer
Observer
You the MAN -:)
Message 11 of 13
AALIMXXPX
Community Visitor
Community Visitor
My warmest thanks
Message 12 of 13
thach_nguyen
thankyou. it works. i like SNAPANG.
Message 13 of 13
vnew
Just saved me.  Thanks!
