AutoCAD crashing intermittantly
Message 1 of 11
I'm using AutoCAD 2015 64 bit on a Dell Latitude E6530.  It has Windows 7 Pro, an i5 processor with 10 GB of RAM, and an Nvidia NVS 5200M video card - also Intel HD Graphics 4000 card.  I have installed all AutoCAD updates, but I still get intermittent crashing of AutoCAD.  Everything I am working on is lost.  The program always restarts, but will simply crash for no apparent reason.  Is this because of the specs on my laptop?  I have scanned for viruses also and performed all Windows updates.  Any ideas would be appreciated.
Replies (10)
Message 2 of 11
JDMather
@Anonymous wrote:
....  Everything I am working on is lost...
Can you save the file before it crashes?
Is the saved file corrupt?
Message 3 of 11
john.vellek
Hi @Anonymous,
I am sorry that you are having this problem. Are there any error messages when this occurs? Does anything show up in the Windows Event Logs?
I would check to make sure that your video drivers are current.  Also, if this happens consistently on one or more drawings can you attach a sample drawing so I can see if there is any corruption?
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 4 of 11
dgorsman
What are your typical file sizes?  Are you working in 2D or 3D?  Does it make a difference if the file is simple or complex?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 5 of 11
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with your results so other Forum users can benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 6 of 11
No error when AutoCAD crashes.  The program simply disappears and I have to reopen it.  I had to turn off hardware acceleration to be able to manage files - the cursor would trail within a drawing - sometimes never going away unless I clicked on the screen.  These are basic DWG files under 1 MB - slightly more sometimes - that have been sent to me from others - not 3D.  Doesn't seem to matter what file I work with.  Pretty simple stuff, really.
Message 7 of 11
john.vellek
Hi @Anonymous,
Which graphics card does AtuoCAD show that it is using?Is it possible to disable the Intel card, and then verify that the most current drivers are installed for the NVidia.
You can see the Card in use by looking at Graphics Performance.
John Vellek
Message 8 of 11
Seems to be two drivers. Intel HD 4000 Graphics Driver, but Nvidia NVS 5200M is listed in AutoDesk. Am looking into a newer driver. Found one for the Intel driver at Dell. Will go directly to Nvidia for that one.
Allan Faulhaber MCP
Systems Engineer
[ace-logo-blue-rgb]
6599 Granger Rd.
Independence, OH 44131
216.236.0249 direct
216.642.9555 office
216.642.9080 fax
[email protected]
Please note: when requesting hardware service or general support you may contact our Dispatch Department via email at [email protected] or call direct by dialing 216.642.7355
Message 9 of 11
john.vellek
Excellent - please update your post with your results.
John Vellek
Message 10 of 11
john.vellek
Hi @Anonymous,
I haven't seen an update from you on whether newer drivers were available and remedied the problem.
As a good practice, I recommend also running Audit and Purge on all drawings that come from outside.  That might help prevent some issues too.
Please update your post.
John Vellek
Message 11 of 11
Following are the basic reasons and solutions behind why the autocad get crashes in window. Try to correct the following situations so that the application could run easily and smoothly on your PC:
  • Update your drivers.
  • Update to the latest video driver from your graphics card manufacturer.
  • If your system happens to have dual graphic cards, disable the Intel video or set AutoCAD to run with the high-performance card
  • Run diagnostic test.
  • turn off Aero by changing your desktop theme to Windows Basic.
  • Also change program settings
Here is Dell Latitude E6530 Manual that will help you most in resolving your issue.
