AUTOCAD CRASHES WHILE USING offset command
chiaradonetti
Message 1 of 8
chiaradonetti
Good evening,
i have an Autodesk account with a student licence and i wanted some clarfication on a program crash that i esperience frequently. This block occurred when i tried to offest a sline, which makes mi unable to continue the work and even prevents me from closing the Autocad 2d program. This hang occurs only when i use the "offest" command. It is a pc problem or a program bug?
Thanks for the attention. Best regards.
[ The subject line of this post has been edited for clarity by @pendean Original: AUTOCAD 2D CRASHES WHILE USING CERTAIN CONTROLS]
Replies (7)
Message 2 of 8
pendean
Community Legend
Community Legend
@chiaradonetti Share with us screenshots of your ABOUT command pop-up as well as your GRAPHICSCONFIG command pop-up please.
If you've never done that before today here is how:
https://support.microsoft.com/en-us/help/13776/windows-use-snipping-tool-to-capture-screenshots
Message 3 of 8
Valentin_CAD
@chiaradonetti ,
Consider the suggestions on these links:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 4 of 8
chiaradonetti
Thank you,
i'm attaching the screenshot of my computer when autocad 2d stop working after the offset command. The other computer's major commands and software remain fully functional. problema offest autocad.png
Message 5 of 8
pendean
Community Legend
Community Legend
@chiaradonetti You forgot to share the screenshots of the two pop-ups I inquired about in my first rely, can you try again?
Message 6 of 8
chiaradonetti
Message 7 of 8
chiaradonetti
Message 8 of 8
chiaradonetti
Sorry, i spam to you 2 errate images. This is the correct one maybe.prestazioni grafiche autocad .png
