AutoCAD crashes when saving render resolution settings
tbrammer
Advisor Advisor
tbrammer
AutoCAD crashes when saving certain render resolution settings. See screencast.
This happend with "vanilla" AutoCAD 2018 1.2 Update  (_VERNUM = "O.161.0.0 (UNICODE)" )
  • no 3rd party apps loaded
  • clean new profile
Does anyone know this problem?
Is there a workaround?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Alfred.NESWADBA
can't reproduce that issue, tried the same steps you have done, same values in the dialog, all works well.
>> clean new profile
Sorry, but ...
  • What I don't see: which template did you use, by default (and with a new clean profile) you would not land in the 3D-view when creating a new dwg.
  • What I see: you don't have the original menu
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
tbrammer
Hi Alfred,
thanks for your quick reply.  You pointed me towards the right direction: It is an issue of the DWT!
It works if I start a new drawing "without template" or with one of the original Autodesk DWTs.
My profile was not so "new & unmodified" as I thought: It used a different DWT that caused the issue.
I noticed that, when I use this DWT and click on render settings, there is no resolution marked:
Calling [Weitere Ausgabeeinstellungen...] would lead to a crash upon save then.
When I simply select any resolution before I call [Weitere Ausgabeeinstellungen...] everything is runs fine.
This is also the solution to fix the DWT: Open DWT select a resolution. Save DWT. Done.
