@john.vellek I had hoped that installing this this would solve the problem of vanilla AutoCAD 2017 and 2018 partially opening and then crashing (although Civil 3D as AutoCAD 2017/2018 works with no issues) but it makes no difference
Hi @neilyj666,
I am sorry that the crash is occurring and that the driver update seemed to have no affect. Can you prepare a NFO file for me to look at? I am assuming that you do not have the opportunity to submit a report to Autodesk when this occurs. If you do, please give me the CER number.
Have you also tried updating your .NET Framework to.NET 4.7.1?
HI @neilyj666,
I am checking back to see if my post helped you with your problem or question. Please mark my post as an accepted solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved. I would like to know if the .Net Framework upgrade resolved your crash issue.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
