AutoCAD copy/paste not working
ym_abuali
ym_abuali
Hello can any one help me please?
I am trying to copy some objects and drawings from file B to file A, but it didn't work.
I tried everything but nothing worked for me.
Please help.
It looks like that there is some issues with file A but I couldn't figure it out
Thanks in Advance
imadHabash
Hi and Welcome to AutoCAD Forum,
it works fine with me ... i can copy and paste from B to A.
Would you make a short video and attache it here to see what happen with you?
Imad Habash
DumR0
hi,
you have some block reference that you will not be copied, you need to insert them ( xfer command)
ym_abuali
(view in My Videos)
Hello again,
Please check my attached video.
ym_abuali
Hello DumR0,
Thank you for your reply.
I used XFER command and brought the entire drawing to the target, then I converted it as a block then exploded it.
At least it is working for now, but why can't I just copy then paste?
DumR0
You need to understand that xrefs (external reference) are links, not ojects, and you cant copy them like block, objects etc. Indeed the are treated as block, but is a special kind of block reference.
You have 3 options for transfer to other dwg. 1 burst/xplode, 2 atach manually in new dwg by xref, 3 Bind/Insert the xref in the source  first( become port of the dwg, so it can be copied)
