Announcements
AutoCad Coordinates not showing smaller values
Hi. I'm new to autocad and I just want to ask why the coordinates being shown in my drawing are so large. Even when its close to the origin 0,0. Im having a hard time drawing lines that are 1,5 because the coordinates wont show smaller values. I hope you can understand my question. Need help please. Thank you. Really appreciate your help.
imadHabash
The best way is to enter the value while drawing . I mean that if you want to draw lines start draw and move your cursor to the side that you need and type the length that you want to get it . for me i have never use those coordinates while drawing lines .
Please ... if you mean another thing , make another message .
Imad Habash
pendean
Community Legend
Community Legend
>>>...I'm new to autocad ...<<<
Do not try to eye-ball coordinates or entries, it is best practice to enter what you want all the time. This is CAD, precision and deliberately entering what you need is the best approach.
Alfred.NESWADBA
Just to make sure ... you are using a "." (point) as decimal separator and not a "," (comma) ... as AutoCAD can only work with "." as decimal character.
So when you draw a line you can always enter smaller coordinates ... like this:
_LINE
0.001,0.001
0.002,0.002
If it's just the numbers shown in LIST command or in the property window then please start command _UNITS and specify the number of decimal characters you want to have.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Thank you so much. Ill try doing this.
Thank you. Will definitely try this.
Noted. Thank you
