AutoCAD Command to reset Block Rotation angle to zero
Message 1 of 8
Hi All,
Please let me know AutoCAD command to reset the block rotation angle to zero.
Replies (7)
Message 2 of 8
john.p.addy
Is the block actually rotated at the 45 degree?
Thank you,
John Addy
Electrical Engineering Tech.
Department of Defense
Message 3 of 8
Thank you for your reply Sir,
Yes, Block has been rotate at 45 Degree.
Basically i am defining a AutoCAD script, where the block to rotate at specified angle and plot the window selection area, then again to reset the block rotation angle to zero for rotate to next angle value and plot.
Thank you..
Harish
Message 4 of 8
tramber
Change the value by clicking in that field with your mouse Smiley Wink
Message 5 of 8
tramber
You can also use the CHANGE command on a block insertion to redifine the angle but it would mean that you select, wich is quite some art in scripts.
Message 6 of 8
john.p.addy
The only thing I can think of is to go into the actual block and rotate the block -45 degrees, or rotate the block -45 degrees
Thank you,
John Addy
Message 7 of 8
Kent1Cooper
@Anonymous wrote:
.... the block to rotate at specified angle and plot the window selection area, then again to reset the block rotation angle to zero for rotate to next angle value and plot.
You could simply do something like this:
Rotate the North Arrow
Plot {whatever that involves}
U ; [undo the Plot, which won't have any effect in the drawing]
U ; [undo the Rotate command]
Rotate the North Arrow for the next....
If that isn't viable for some reason, and if you have full AutoCAD and therefore AutoLisp capability, and if there is only one such Block in the drawing, you can just force it to be at 0 rotation:
(vl-load-com); if necessary
(vla-put-rotation (vlax-ename->vla-object (ssname (ssget "_X" '((2 . "NorthArrow"))) 0)) 0)
Kent Cooper, AIA
Message 8 of 8
leeminardi
The following vlisp code uses the ALIGN command to  reorient a 3D block so that its axes are parallel to the WCS.  It "unrotates" the block.
(defun c:unrot (/ bdata bm xv yv pos spt2 tpt2 spt3 tpt3)
; rotates a block so that its axes
; are aligned to the WCS
; L. Minardi  2/20/2018
  (setq bdata (nentsel))
  (setq bm (nth 2 bdata))
  (setq	xv  (nth 0 bm)
	yv  (nth 1 bm)
	pos (nth 3 bm)
  (setq	spt2 (mapcar '+ pos xv)
	tpt2 (mapcar '+ pos '(1 0 0))
	spt3 (mapcar '+ pos yv)
	tpt3 (mapcar '+ pos '(0 1 0))
  (command "align" pos "" pos pos spt2 tpt2 spt3 tpt3)
  (princ)
lee.minardi
