AutoCAD - Command Line refuses to stay docked/locked
- Mute
- Permalink
- Report
Hello all,
There was a discussion earlier about AutoCAD pallets changing size for which a solution was accepted (here): https://forums.autodesk.com/t5/autocad-forum/why-do-side-docked-palettes-change-height-between-sessi...
That solution does not solve this problem.
There is only one solution I've found that keeps everything exactly as intended, but only AFTER the governing .xml file is edited and then made read-only (the solution discussion is here): https://resources.imaginit.com/support-blog/command-line-will-not-stay-docked
This solution has one major downside. ALL of the things that should be written to this .xml file can no longer be written to it because the file is read-only, e.g., recent file lists become static/stagnant (both .dst and .dwg). That's a problem.
Does anyone have a clue to why the <CommandLineControl Workspace="<your workspace name>"> tag is either not written or written incorrectly to the .xml file (%appdata%\Autodesk\<your product version and year (i.e. AutoCAD 2020, C3D 2018, etc)>\R##.#\enu\Support\Profiles\<Profile Name from Options box>)?
It seems that if the cause of that failure/error were identified we could eliminate this docking problem.
[The subject line of this post has been edited for better findability by @handjonathan Original: Command Line refuses to stay docked/locked ]
Authorized Autodesk Developer
Civil Design Specialist – Water & Wastewater Infrastructure
