AutoCAD change color of text in Multileader
m_peker70
m_peker70
Hello friends
i wanna to change text color of multinater o properties window but there isn't such option of this window.
actually i do matchprop that multinater object it happines great without text color. ıt statius is too annoying
best regards
Erense
I am not sure exactly it is you want.
For a Multileader you can create you own Multi-leader style where you can define the way it should look.
On the Tab 'Annotate'  click the 'slanted' arrow next to 'Leaders'
This opens the 'Multileader Style manager'
create and adjust any style to your liking.
When you click [ Set current ] every next Mleader created wil follow these settings.
Once created you can change either the Mleader style to the style you want/created,
You can also change the way the text looks from the properties:
Click  the line behind 'Contents'
Click the new 'screen' button. The Text editor tab opens
Here you can change the appearance o f the text for this one Mleader.
Hope this helps.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
m_peker70
Hello Freend
Thanks you for help me.
Actually, I usually use many size kind of multileader. For example "Hight 10 Yellow,Hight 10 Blue".
When I want to change feaature of a multileader, I have selected a multileader. I change color of multileader line on properties window. But It doesn't look color menu on text properties window, when multileader was selecting. That's way i change color of multileader text with "edit text" command. So extra work for me.
Best Regards
"It's hard to imagine a world without the forest"
S.Faris
In the multi-Leader Style manager, Modify your style and choose a color under the 'Leader Format'tab (assuming that all your multi-leaders lines and arrows are of a particular color and that you just want to change the color of the text).Under the 'Content' tab choose 'byblock' for 'text color'.
Now select the multileaders and then change the color(Color under General tab) from the properties tool, which will only change the color of the text.
SALMANUL FARIS
m_peker70
Hi S.Faris
Thanks your solution.
My problem solved. if selected a color ""content" tab text color "ByBlock" it not be problem.
I learned something from you.
Best Regards
