AutoCAD - Cannot rotate ole object in a specific file
mzmaso90
mzmaso90
Guys, I cannot understand a valid answer to solve this problem. The object do not follow the angle or normal degrees i need to move toward. Is anyone able to solve this rotate problem? Kind Regards
Lorenzo
[ The subject line of this post has been edited for clarity by @handjonathan Original: Rotating desidered fail - ]
pendean
Community Legend
Community Legend
Not enough information: try again please, include video or lots of screenshots and a DWG file when you can.
mzmaso90
https://autode.sk/3SGBbrp i Try again, but i don't know if you can see...
Kent1Cooper
Does it happen with all object types, or only OLE objects?
Kent Cooper, AIA
cadffm
mzmaso90
It Happen  only in this file, not the others I  opened, I now tried, only OLE I think, i tested  PDF import and is correct
mzmaso90
Is that easy or might require more than general skills to get ahead of it?
