AutoCAD Forum
AutoCAD - Can't delete xref with no name
10 REPLIES 10
Message 1 of 11
maria.m.valle
468 Views, 10 Replies
I have a xref with no name that's unreferenced that I can't delete/detach. I've tried to copy everything that I have to a brand new file but the xref won't go away. I only have one other xref that I frequently use in other files and I never had a problem with it. Also, I don't have blocks on this file. Can someone help delete/detach it?
[ The subject line of this post has been edited to include the product name by @handjonathan ]
10 REPLIES 10
Message 2 of 11
Hi @maria.m.valle
Thanks a lot for posting your question to the forums! I would start by auditing the drawing and then taking a look here for potential fixes.
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Message 3 of 11
RobDraw
in reply to: maria.m.valle
Try repathing it to an existing image..
Rob
Message 4 of 11
Audit, purge, unlocked all layers... nothing worked!
Message 5 of 11
maria.m.valle
in reply to: RobDraw
Still unrefrenced and won't detach. ( I also tried to purge and audit the file again!).
Message 6 of 11
paullimapa
Share your problem dwg file
Paul Li
IT Specialist
@The Office
Message 7 of 11
maria.m.valle
in reply to: paullimapa
For private reasons I cannot share the the drawings, however I decided to delete everything in the file, audit and purge it and still the unrefrenced xref won't disappear. I'm sending the file so you can see it.
Message 8 of 11
RobDraw
I tried several things without success. As a last resort, I tried EXPORTTOAUTOCAD. It worked. I'm guessing the image is in an element within a library from a vertical product that was purged during the export process.
Rob
Message 9 of 11
maria.m.valle
It worked! Many thanks
However can you explain what you mean with "library from a vertical product"?
Message 10 of 11
RobDraw
Vertical products such AutoCAD Architectural store libraries in each file. The export gets rid of them.
Rob
Message 11 of 11
maria.m.valle
Thanks for the explanation and help!
AutoCAD Inside the Factory
