AutoCAD - Bulk Block Rename
Seychellian
Message 1 of 10
Seychellian
Hi I searched google for this and couldnt find a solution.
I am shifting a block library to a new company name and I need add a prefix to all the blocks (1000's) to differentiate them. I know you can rename blocks with the RENAME command in AutoCAD but how can i bulk rename them to avoid the laborious task of doing each one individually?
Thanks!
[ The subject line of this post has been edited for clarity by @handjonathan Original: Bulk Block Rename ]
Replies (9)
Message 2 of 10
ВeekeeCZ
You would need some LISP that renames all necessary blocks in one file - without failure. Use can use THIS one for example, but you can find plenty of others.
Then you would need a SCRIPT PRO HERE to apply the lisp across the files...
Message 3 of 10
tramber
  • Blocks as separated dwgs in directories, you need a software as the lovely Ant Renamer
  • Blocks recorded in a drawing ? You could list them or do you have a computated list of names already ? In such case, Excel and a script built with is a natural and easy solution. Try the command -RENAME (not RENAME), it shows you that it can be done with script. But you need a list of precise names in order not to fail. Or you need a lisp that test each name, in case.
Message 4 of 10
3wood
If all blocks are in current drawing, you can use wildcard to rename all of them in one go.
Message 5 of 10
tramber
Well done @3wood because, yes, wild-car is allowed..., i forgot that !
Message 6 of 10
Kent1Cooper
[Just be aware that the * wildcard approach in RENAME works only to add a PREFIX to all Block names.  You can't add a SUFFIX to all of them that way.  That's enough for the OP's request, but there is that limitation.]
Kent Cooper, AIA
Message 7 of 10
cadffm
and here we talking about PREfix 😊
Suffix is also possible, but only by one step for blocks with the same name length.
I you have blocknames, all with the same length, one step for all blocks.
???suffix
Sebastian
Message 8 of 10
paullimapa
Try my free BlockApps which includes a Rename multiple Block feature
https://apps.autodesk.com/ACD/en/Detail/Index?id=3309945226076337959&appLang=en&os=Win64
Paul Li
IT Specialist
@The Office
Message 9 of 10
Seychellian
This is EXACTLY what im looking for. It's very rare that happens.
Thanks a lot. Youre a life saver!
Message 10 of 10
paullimapa
Glad that worked out for you...cheers!!!
Paul Li
IT Specialist
@The Office
