AutoCAD - Block name inside block with text field?
aclima01
Message 1 of 24
aclima01
Hello
It would be very useful for me to have field text inside a block that will show the name of that block and update it when the block is renamed. Can anyone tell me if this would be possible?
I don't think so, but not sure...
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Replies (23)
Message 2 of 24
ВeekeeCZ
Yes it is. Just look for NamedObject/Block... Easy peasy.
Message 3 of 24
vinodkl
Yes it's possible(see attachment)
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 4 of 24
jnksimmons
I created a block and used a field to label the block with the block's name. The block is a raw good that is used over and over. I name the the block the actual part # of the raw good. I used the block in several files. I then needed to change the name of the block which was it's part number. I did that and the field changed as well which is exactly what I wanted. The problem is it did not change in my other drawings. I tried the attsync command but is said this drawing contains no attributed blocks. I need all instances of the block to update across several files. Any help is greatly appreciated.
Message 5 of 24
TomBeauford
Most fields are drawing specific if you place any object referenced by a field into another drawing it's no longer linked.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Message 6 of 24
henrik.pettersson
I have the same question, but I found the NamedObject-field and it doesn't really do what I want.
Is there a way to display the current blocks name as a text in that same block?
If I create a block with NamedObject, copy that block, saves it as something else to make a slightly different block, then the field is still referencing the old block and displays that name, not the name of the block which it is acctually in.
I see it as I want an attribute to display the [Name] parameter of the block, but I can't find a way to do so.
Message 7 of 24
cadffm
Create your Attdef in BEDIT, default value -> add a field: Object->Blockplaceholder->Name
or paste this code: %<\AcObjProp.16.2 Object(?BlockRefId,1).EffectiveName>%
Sebastian
Message 8 of 24
henrik.pettersson
Thank you.
Had to fiddle with some visibility settings but it works.
Can also note for other users that the ref updates with save or print or update-command. It doesn't update when you RENAME or Save Block as, you need to save the file first.
Message 9 of 24
cadffm
Read more about FIELD FIELDEVAL  FIELDDISPLAY UPDATEFIELD
[F1]
Sebastian
Message 10 of 24
v_harutyunyan
I have the same issue: I want to display block names inside or under the blocks in the drawing. Please describe your solution above in step by step instruction.
Message 11 of 24
v_harutyunyan
How to do it?
Message 12 of 24
cadffm
edit your Block: BEDIT
Create a MTEXT by FIELD command
  or edit your existing (M)Text, inside the editor RightClick -> insert field
Inside Field dialog
From upper left to the right..
Category Object
Fieldtype Blockplaceholder
Blocks
Name
Sebastian
Message 13 of 24
v_harutyunyan
Thanks @cadffm, but it pops up "invalid field code". (I use AutoCAD Mechanical 2024) See below:
Message 14 of 24
cadffm
Are you in BEDIT as I described?
Sebastian
Message 15 of 24
v_harutyunyan
Yes
Message 16 of 24
v_harutyunyan
Do I need to do it manually for all blocks? Is there a way to do it for all of my blocks by one command? I have almost 50 blocks in my drawing.
Message 17 of 24
cadffm
For each Block.
Sebastian
Message 18 of 24
v_harutyunyan
Thanks, I am willing to do it for each block, but please explain how to do it. I have entered BEDIT command, chosen the block, did RightClick -> insert field, etc. But it doesn't work. Can you please provide some screenshots.
Message 19 of 24
cadffm
You screenshot says: You are NOT in bedit.
https://m.youtube.com/watch?v=YR1jqkV6UBA
Sebastian
Message 20 of 24
cadffm
Sorry, my fail!
It works with ATTRIButes only!
Create an ATTDEF (property constant = yes)
Default content: Insert field
Blockplaceholder
Big SORRY
Sebastian
