AutoCAD Block Attributes: Block Instance Attribute Visibility
Jake_CAD
Jake_CAD
Can Block Attributes be hidden for block instances but still visible in the properties palette (and available for data extraction)?
I wish to utilise block attributes to hold block-instance specific meta-data (eg. Manufacturer, Material, Cost, Electrical/Mechanical loads) that can be scheduled out (using Data Extraction Wizard), while remaining invisible in model space.
I have tried hiding the attributes using Visibility States, but when hiding using this method, the attributes do not show in the block instance properties and are not available for data extraction.
Any advice or suggestions welcome.
paullimapa
Use Attribute Definition's Invisible Mode
Paul Li
IT Specialist
@The Office
Jake_CAD
Well that was an easy one - thank you!
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
