AutoCAD Best Practice: Model View Workflow in AEC Projects
Query: I am looking for advice on working with Model Views in AEC projects - where certain views require multiple x-refs to be displayed.
Context: As I work within the AEC industry, my current work flow uses Individual X-refs for each storey (eg. Site Plan, Ground Floor) & a single Sheet File which combines the x-refs (of all storeys) and contains all of the project sheets.
At present, I can see 3 options listed below, so I welcome comments on these and/or proposals for alternatives;
- Set up Model Views in Sheet file (with all required x-ref objects displaying). The issue with this is that when these Model Views are placed through the Sheet Set Manager (SSM) onto sheets within the same file (& become listed in the 'Layout Views' of the View Manager & 'Sheet Views' tab of the Sheet Set Manager), they are suffixed with a (2) because it is seen as a duplicate of the model view within the same file - and as such requires each view name to be edited.
- Set up Model Views in X-ref file(s), nesting other X-refs to create the desired object display. The issue with this is that when each Model View is placed, a separate version of each x-ref is placed in the Sheet file.
- Create a dedicated Model Views file for combining X-refs and creating Model Views. The issue with this is that is it introduced a 3rd layer into the tree (Sheet File > Model View File > X-ref(s)), increasing workflow complexity.
*CLARIFICATION UPDATE: We have a single Sheet file that contains all project sheets.*
