AutoCAD Best Practice: Model View Workflow in AEC Projects
Jake_PCH
Jake_PCH
Query: I am looking for advice on working with Model Views in AEC projects - where certain views require multiple x-refs to be displayed.
Context: As I work within the AEC industry, my current work flow uses Individual X-refs for each storey (eg. Site Plan, Ground Floor) & a single Sheet File which combines the x-refs (of all storeys) and contains all of the project sheets.
At present, I can see 3 options listed below, so I welcome comments on these and/or proposals for alternatives;
  1. Set up Model Views in Sheet file (with all required x-ref objects displaying). The issue with this is that when these Model Views are placed through the Sheet Set Manager (SSM) onto sheets within the same file (& become listed in the 'Layout Views' of the View Manager & 'Sheet Views' tab of the Sheet Set Manager), they are suffixed with a (2) because it is seen as a duplicate of the model view within the same file - and as such requires each view name to be edited.
  2. Set up Model Views in X-ref file(s), nesting other X-refs to create the desired object display. The issue with this is that when each Model View is placed, a separate version of each x-ref is placed in the Sheet file.
  3. Create a dedicated Model Views file for combining X-refs and creating Model Views. The issue with this is that is it introduced a 3rd layer into the tree (Sheet File > Model View File > X-ref(s)), increasing workflow complexity.
*CLARIFICATION UPDATE: We have a single Sheet file that contains all project sheets.*
Simon_Weel
We use the 'plot file' approach, like option 3. I.e. a host file for all xrefs. And a layout for each drawing you need. Don't create layouts in the x-refs.
Not sure what you mean by introduced a 3rd layer into the tree? You have one host dwg for each storey, and that has all the necessary files x-reffed into it.  And then Layouts for the parts you want as a sheet.
Jake_PCH
*OP UPDATE: For clarify, I have changed the term 'Host file' to 'Sheet file' - I have clarified this in the OP and will be using it going forward.*
I do not create layouts in x-refs but the 'Sheet file' contains ALL of the project sheets (ie. I do not have separate 'Sheet files' for each storey).
The 3rd layer/file (Model View File) would be introduced between X-ref(s) & 'Sheet file' to avoid AutoCAD from identifying the placed Model Views as duplicates & subsequently suffixing with a (2).
Simon_Weel
If I'm correct, you have a lineup of all drawings linked in a single dwg file. Then you create a layout for each sheet and create a viewport on that sheet for that particular drawing.
This I don't get:
I guess you duplicate a layout to create a new sheet? That would indeed add a number to the name of the layout. Just change the name of the layout?
Jake_PCH
'Sheet File' & associated Sheet Set Manager attached.
Screenshot embedded within OP & video demonstration  below;
