AutoCAD Ball Joint Drawing/Model
Reference Post: Ball Joint Drawing Model
Yeah..how to draw ball joint in AutoCAD?? I don't know.
johnsonshiue
Hi! This is Inventor forum. Are you using AutoCAD or Inventor? There is an example of ball joint assembly here. If you have access to Inventor, you can open the files and take a look how they were created. The way to model them in AutoCAD is slightly different. You will not be able to establish constrain relationship easily. If you just want 2D drawing in AutoCAD, actually AutoCAD can create associative drawing views from Inventor assemblies and parts. The command is called VIEWBASE.
Many thanks!
Software Test Engineer
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I would start by switching to a 3D workspace
Now, create a SPHERE
Next, create a CYLINDER and push it partially into the sphere and use UNION to combine them
Now, you can make the socket portion. You can use another cylinder to do this or a box, or any other solid shape.
Now create the socket or void in the last cylinder using another sphere and by using SUBTRACT
Now you can place the ball part into the socket
I realize this is over-simplified but perhaps it will get you started.
If you have more exacting requirements and need extra help or resources, please add a post.
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
