AutoCAD - Associative array defaults to defpoints layer
kameron.jones
kameron.jones
whenever I create an associate array, it changes the association to defpoints. Is there a setting to change this? I generally don't use associative arrays for the work I do as I array the base piece then add the differences on top of the new objects but every now and again I update or upgrade and forget to change that, but I wouldn't mind the associative array if i could change the default layer. Thanks for your help in advance!
[ The subject line of this post has been edited for clarity by @handjonathan Original: Associative array defaults to defpoints layer ]
Kent1Cooper
Was DEFPOINTS the current Layer when you started the ARRAY command?  It puts the Array object on the current Layer, no matter what the Layer(s) of the selected object(s) -- after all, that could involve multiple Layers, so it can't choose a single Layer from among those, to put the Array object on.  If you Explode an Associative Array, the resulting pieces are on the original Layer(s), not [necessarily] the Layer that the Array object was on.
Kent Cooper, AIA
kameron.jones
Haha, I knew I was doing something wrong thanks Kent, I think I fat-fingered a layer and changed my layer to defpoints... I think that is it.
