sir
I send a reference drawing for your review and Comments,
kindly please advise me...
[ The subject line of this post has been edited for clarity by @handjonathan Original: Arrow Head Not Visible ]
Solved by Alfred.NESWADBA. Go to Solution.
maybe it's a layer matter ( off / freeze ) OR it's an draw order issue ( bring to front ) . would you please attache your CAD drawing to give you more help ?
i suggest to change all of your Layout to a new one . your issue will be solved if you make a new layout from scratch.
do you mean the arrows of the multileader objects?
If so please start command _PAGESETUP ==> modify and activate the option "Plot Paperspace last"
Then the multileader objects on paperspace will be regenerated after the viewport contents and so visible.
- alfred -
Alfred,
Thank you. Again I learned something from you.
Dave
Dave Stoll
Las Vegas, Nevada
Hi Dave,
you are very welcome!
- alfred -
I was having the same problem, so I copied/paste an existing drawing into a new model, and now I see the arrows, however they are miniscule. I modified the size to 0'-0 3/8" and the arrow + text is small in both model and layout view. Started a completely new drawing I can see the arrow +text, but still quite small. I'm a student and uber new to AutoCad for Mac.
Thank you!
having same problem. My "plot paper space last" is checked already and dimmed so not changeable at least from that dialogue. Also my leaders are now consistently showing behind my drawing features which has never done before. Autocad LT 2020 latest build seems buggy.
Which command did you start so that this option can't be changed? Also, any chance to see a screenshot from that?
Please upload a dwg-file where I can see this issue.
- alfred -
No, you have another problem and should start your own Thread after searching solutions and some tests.
The option is greyed out if you try to plot from the Model tab. Model Tab => No Paperspace => No "plot paper space last"
If you have problems with the object display order:
Check SORTENTS and DRAWORDERCTL, set it to the default value, which you can see in your help [F1]
Use DRAWORDER to chance the order of display, [F1]
But first: Make sure you are using an updated product., Command: ABOUT
Still a problem?
Upload Screenshot of ABOUT dialog and share the ZIP from Command: ETRANSMIT
Sebastian
You are so right, I never think about using plot from modelspace.
- alfred -
Thank you for the several suggestions:
1. I assume since I have a product license it updates automatically. I know it performed an update sometime in the last few weeks. I found a hotfix download but it had zero instructions on what to do with it since it isn't a .exe file and no link to help on adding a hotfix.
2. In paperspace (layout tab) the plot paper space last option is checked
3. The draw order was set for the leaders to be on top so unclear how that effects having arrows draw or not (are they a separate object from the leader? Their is no option I could see for "draw arrows on top").
4. F1 unclear about sortents command and what would possibly be the correct setting to use or what this even does since it points you to draworder.
Anyway, this seems to be a long running problem in Acad but is random. I've posted the .dwg in case that helps.
Your Arrow is missing in MODEL tab too,
Annotation problem / mleader style..
Create a mleader M U C H bigger (across the whole drawing, the the arrow again)
OR
Set CANNONSCALE to 1:1 to see the first time your "arrow" when you create a NEW mleader.
The Problem is your Arrow-SIZE in the style and your existing mleaders.
Set the size much smaller..
Sebastian
You are using an Annotative Multi-Leader. Your viewport scale, your drawing scale and the annotative scale of your multi-leader are all consistent. Yay! Good job!
Your arrowheads don't show up because they are too big relative to the arrow shaft. Even if the shaft was extended your multi-leader would look goofy when compared to the associated text height.
To make the arrows display without making your multi-leader look funky, do this:
1-Expand the Leaders panel.
2-Modify the style named Architectural Standard.
3-Change the Symbol style and Size as shown. (Don't forget the " symbol (inches).
You should read all answers and read about the settings/command/variables.
I tried to sow you what the problem is, so you are able to read about it and test several settings #15
1. You are working with annotation styles, do you know what this feature is and how it works?
2. As i said: your Arrow head is to big (not enough space for such a big arrow)
Test it: Draw one bis mleader across the whole drawing and you will see the BIG arrowhead, right?
3. Solution: Set your arrow SIZE (first tab in mleader-style dialog) to 5/128" for example
Sebastian
Thanks, that helped. I had followed #16 and the suggested size didn't have any effect. Your suggested size did the trick. I do get very confused by the lack of WYSIWYG in Autocad compared to GIS programs I'm more familiar with. There seems to be inordinate guesswork in figuring out text and leader sizes for example.
Your multi-leader should be in modelspace, not paperspace, and have annotative properties. When your drawing scale is consistent with your VP scale your annotative objects such as mleaders will automatically adjust.
