AutoCAD & Bluebeam Drivers - Title block off centered when plotting to pdf
nlair1001
Message 1 of 11
nlair1001
Hello there. I'm having an issue with paper space. When I go to export a sheet or sheet set to PDF, the title block and viewport are shifted down and to the left consistently. In paper space, both are centered on the page. I looked at the PC3 file as well and my margins are set to 0 (not sure if they are supposed to be). I can rectify the problem by setting my plot offset to .125" for X and Y but that is very inefficient and annoying. I can also rectify it by shifting the title block the same amount in paper space. Any help on the issue would be greatly apricated.
(side note, when plotting to my actual printer the title block is perfectly centered).
Paper space
Plot to PDF Preview
@nlair1001 - moderation has adjusted the title for clarity.
Replies (10)
Message 2 of 11
baksconstructor
You need to select in the print settings the format with the inscription - without borders.
You have selected fields. And the top margins compress the drawing vertically. Since the vertical is less than the horizontal, there is a difference with the remaining space. At the same time, there is more free space in width. And when there is more space than you need, displacement occurs.
The second option is to set Centering in the print settings.
Message 3 of 11
pendean
Community Legend
Community Legend
You forgot to share the PLOT command pop-up to show the settings that lead to your PREVIEW @nlair1001
Message 4 of 11
nlair1001
Ah apologies, here it is. Let me know if you need any more information. Thanks! @pendean
Properties tab:
Message 5 of 11
nlair1001
Hey @baksconstructor. When you say print settings, are you referring to a setting in the "Plot and Publish" section of the options tab? Or are you referring to the paper size drop down from the "Plot" command dialog box? Or neither haha! If it is the latter of the two, I don't see an option with that inscription available to select (see below).
Thanks!
Message 6 of 11
pendean
Community Legend
Community Legend
This is not the forum for
You want to go over there instead
https://support.bluebeam.com/
Message 7 of 11
nlair1001
@pendean Sorry if I made this confusing, I should have clarified this issue persists with any AutoCAD PDF driver not just Bluebeam unfortunately. Just happens to be the one I use most of the time.
Message 8 of 11
pendean
Community Legend
Community Legend
@nlair1001 wrote:
this issue persists with any AutoCAD PDF driver not just Bluebeam unfortunately...
I can't replicate your issue here
Message 9 of 11
nlair1001
Huh bizarre... Do you think it could maybe be an issue with my PC3 files? I'm under the impression my print area offsets should be at 0, but my coworker does have offsets in those fields. Appreciate your time, thanks for trying to replicate @pendean
Message 10 of 11
pendean
Community Legend
Community Legend
@nlair1001 wrote:
...but my coworker does have offsets in those fields...
I would recommend you both match up 100% and see if that resolves the differences. Offsets are a good way to correct certain issues like these for some users.
Message 11 of 11
baksconstructor
Cool.
After your screenshots everything is much easier!!!
Your drawing print size is smaller than the sheet print area.
Accordingly, your small print area is shifted to the lower left corner.
Solution :
Or select - Center
Or select - Fit to page
Well, as a recommendation - use your own DWGtoPDF printer so that there are no problems.
