Autocad Active X support missing
Dears,
I'm getting this error message when i try to lunch an application called Armacad on my Autocad 2019. this app is working perfectly on 4 other computers but something is going wrong on this one.
Armacad is a rebar drawing app.
I try to installer the VBa enabler but that didn't solve the problem.
thanks.
Alfred.NESWADBA
message "Library not registered" does not automatically mean that AutoCAD ActiveX is not working.
Best you might do now is to ask the vendor of that application.
If you want to set by yourself ActiveX for AutoCAD you might create a small VBA app in e.g. MS-Excel and see if "GetObject" or "CreateObject" can access AutoCAD.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
