AutoCAD 2025 - Cannot use ALT + TAB to switch between drawings anymore
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Autodesk community, I have recently tried AutoCAD 2025 and found out that it is not possible to use ALT + TAB to switch between open drawings anymore. This is an essential part of my workflow to the point where I prefer to stick with the previous version to preserve this functionality. I am wondering if this change was done on purpose, and if there's any way to get around it. I have also attached screenshots which demonstrate the old and current behavior. Thank you very much for your time!
P.S: I am aware of CTRL + TAB, however it switches between the current drawing and the drawing that comes after in the File Tab, not the drawing I was viewing prior to the current one. I am also aware of setting SDI to 1, which opens each drawing in a separate window, however this is a legacy command and significantly increase the time it takes for a drawing to open, disables the file tab and interferes with the Publish command.
