Hello I have problem after install AutoCAD 2025 All workspace is missing.
Previous Version like 2023,2024 After install software All workspace show normally
Anyone have problem same with me ?
Looks like the cuix ribbon menu did not load.
At the end of the 2025 installation, did you remember the request for Migrating previous versions?
Perhaps something went wrong during migration.
What happens if you Reset AutoCAD to defaults?
When click Migrating show error can't migrate ,And Reset setting to default not solve problem.
i Try type Ribbon on command it show Unknow command
Try follow step from article not solve
Reinstall visual C not solve
Reinstall AutoCAD not solve
Update driver graphic not solve
Try load cuix still same don't have anything change
*Try Create new profile windows Ribbon show normaly*
There appear to be many issues involved with your installation. You will need to uninstall, restart your PC, then reinstall 2025, it looks and works just fine for us here
Yes i Try uninstall and install again from Direct link download method problem still have, Gear on right bottom panel i try change workspace still nothing happen on ribbon
@engineer1 Log into your PC as an all new user with full admin rights, then start AutoCAD 2025: does the issue still exist?
The tip above is quicker than finding a second PC or reformatting your one PC.
@engineer1 wrote:Yes if create a new user profile windows software open normally don't know why.
A new log-in is a quicker easier method of REMOVE, REINSTALL AND RESET OS, AUTOCAD AND USER LOGIN PROFILE.
So it appears you have a system level issue preventing AutoCAD2025 from running normally. Not sure anyone here can help, you'll want to engage with an IT person and perhaps Autodesk Direct Support through your accounts page.
May be TRY (Ctrl+F1)
my system often show like this and for me it Restore
