AutoCAD 2024 Issue Opening Files
mdarien4AQ94
Message 1 of 13
mdarien4AQ94
I just downloaded AutoCAD 2024 yesterday, and now I'm running into something I've never seen before when opening files. If I have AutoCAD already open, and I open another file through file explorer, the AutoCAD application will open a second time to show the new file. I've looked at SDI and that's set to 0. What setting is off?
Replies (12)
Message 2 of 13
dmfrazier
Message 3 of 13
Valentin_CAD
@mdarien4AQ94 ,
or
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 4 of 13
nrz13
Is it actually opening another instance of the program, or is it just showing each drawing on the taskbar?
Check out the TASKBAR command:
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-C72AE884-5FDE-4F67-8549-0A6183AC04BB
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 5 of 13
mdarien4AQ94
It is loading another instance of the program instead of opening another tab on the already open AutoCAD program.
Message 6 of 13
Valentin_CAD
@mdarien4AQ94 ,
Don't forget to restart your Computer.
Emilio Valentin
Message 7 of 13
paullimapa
check in AutoCAD if SDI is set as 0
Paul Li
IT Specialist
@The Office
Message 8 of 13
pendean
Community Legend
Community Legend
@mdarien4AQ94 wrote:
I just downloaded AutoCAD 2024 yesterday, and now I'm running into something I've never seen before when opening files.... What setting is off?
you seem to be having the same issue many 2023 installation did this time last year, this is the fix
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/DWG-file-type-asso...
HTH
Message 9 of 13
mdarien4AQ94
Thanks for the solution, this does work. It's a shame though that the file type changes from "DWG" to "AutoCAD Drawing". Instead of showing the DWG blue/yellow file next to the name, it just looks like a white sheet of paper. Oh well, the main issue is resolved. Thanks!
Message 10 of 13
nrz13
Does the blue/yellow icon return once you restart your computer?
Message 11 of 13
mdarien4AQ94
After a restart, that does not appear to do anything.
Message 12 of 13
pendean
Community Legend
Community Legend
...Instead of showing the DWG blue/yellow file next to the name, it just looks like a white sheet of paper...
Not seeing anything like that here, except for BAK files. Do you have file extensions set to show in WindowsOS?
Did you try fixing it https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/generic-icons-show...
Message 13 of 13
David_M_CrawfordTGMB5
Observer
Observer
This fix did not resolve the issue on my machine, I am running Windows 10 and I followed the "using the control panel" , then selecting "Set defaults by app"
But AutoCAD does not show in this list,
Could this be the problem? If if select "choose default apps by protocol" and scroll down to the .DWG, .DWT etc. I can select the AutoCAD or Launcher per applicable extension.
