I get the above message almost every time I click save while working in a drawing. This has been going on for months. Does anyone know how to fix this please?
thanks
[ The subject line of this post has been edited for clarity by @handjonathan Original: 2023 version will not save dwg file ]
Solved by pendean. Go to Solution.
Our IT dept has looked at it multiple times but they are not familiar with AutoCAD so no solution has been suggested or found. We use Windows 11, and there are not any other sessions open.
Familiarity with AutoCAD is no necessary, as I noted above (see below), share this link with them when you get chance https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Saving... and this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Unable...
You also did not answer my last question: did that tip fix the problem?
I'm not seeing a file manager setting. we use Windows Explorer, but I can't find any settings
This needs to be turned off (unselected, no checkmark)
