AutoCAD 2023 image map issue
lwc-light
Message 1 of 14
lwc-light
I create a new material with image map. When I attach it to the cylinder, it always display two circles. How can I get rid of the second circle? I think it is likely the bug of AutoCAD. Anyone can answer this question?
Replies (13)
Message 2 of 14
vinodkl
Hello @lwc-light
Try adjusting the size of the image and use the command "MATERIALMAP" to map the material to the cylinder 🙂
Check this video for your reference AutoCAD How To Apply Texture In Cylinder Object Tutorial For Beginner
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 14
lwc-light
I have seen that. I try to follow the youtube instruction. It always display two circles in the cylinder. The materialmap command also has bug. No matter I move the arrow of direction, the image map of a cylinder does not move. But the image map of a box is able to move any directions. It is probably a bug! Or someone hack the AutoCAD!
Message 4 of 14
vinodkl
Hello @lwc-light
I tried to create similar situation on my end on AutoCAD 2023 and I didn't any issue with material mapping. Can you share you drawing, so I can look into it?
Message 5 of 14
lwc-light
It's nothing special of the drawing file. You can test it.
Message 6 of 14
lwc-light
What is your conclusion after you test the situation? I still can't remove the second circle in the cylinder.
Message 7 of 14
leeminardi
Unlink the the width-to-height aspect ratio then double the value of the width to halve the number of tiles for the width.  Experiment with height and width value till you get a combination you like.
lee.minardi
Message 8 of 14
lwc-light
The drawing still displays two **** circles. Could you give me all the parameters of the material and the size of the cylinder? I want to draw the exact same thing as your drawing in order to point out the ridiculous bug!
Message 9 of 14
leeminardi
The control of material mapping in AutoCAD is very awkward and I can understand your frustration. The challenge is increased when working with an image like a circle where you do not know what is up or down or if the image is rotated.   Sometime I apply the standard checker material to get a feel for how the mapping is being applied.  For example,  in the image below you can clearly see that where the seam lies.
Since the radius of your cylinder is 100, the circumference is about 628.  Entering this for the width yields.
Switching back to referencing your circle image yields.
and the circle is clipped at the seam.  Now you would think, or at least I would,  that you could could edit the offsets and scale and get one image.  I tried with little success. Note that if Tiling is set to none, two tiles appear when there should only be one.
This leads me to the conclusion that there is a bug in AutoCAD (2023) with cylindrical tiling.
You could experiment with an image that has a larger background but my advice would be to use  3ds Max which has exceptional controls for material mapping.  AutoCAD material mapping is just too primitive with an awful user interface.
lee.minardi
Message 10 of 14
lwc-light
We have the consensus now. Next, how do I solve this issue? I need to attach an image map with ONE circle. I am not used to using 3ds max.
Message 11 of 14
leeminardi
Will you need to view the cylinder from more than one vantage point? If not, then you may be able to adjust the mapping so it looks good from one direction.  Here's an example.  I used the attached image file with more round numbers (i.e., 500x500) for the size.
lee.minardi
Message 12 of 14
lwc-light
This is not the solution. I need exactly one circle in the image map. Does the bug only exists in AutoCAD 2023?
Message 13 of 14
leeminardi
"Does the bug only exists in AutoCAD 2023?"
I don't know as I do not track AutoCAD bugs. If the bug were to be fixed it would probably take a while.
In the meantime if all you want is a circle pattern you could achieve that will a few cylinders and some Boolean operations as I did here.
lee.minardi
Message 14 of 14
lwc-light
It’s not an option. I need a version of AutoCAD without this ****ing hacker or bug such as the following link:
https://m.youtube.com/watch?v=ziM57VzSfW4
The youtube shows the material mapping without bug. Which version is it?
