AutoCAD 2023: How to initiate “block editor” for blocks inserted in a table?
JamaL9722060
Message 1 of 10
JamaL9722060
I couldn’t figure out how to initiate “block editor” for blocks inserted in a table as the “block editor” doesn’t appear when right clicking the block inserted in a table
Jamal Numan
Replies (9)
Message 2 of 10
RobDraw
If you know the name, I believe you can select it from the list inside the block editor. (Sorry, I can't test ATM.)
As an option, just make a new insertion of the block and edit from there.
Rob
Message 3 of 10
JamaL9722060
I got the answer. The “design center” tool offer accessing blocks inserted in a table
Jamal Numan
Message 4 of 10
ВeekeeCZ
Whats?
Pick a cell to know a block name, hit BEDIT icon or command, pick a block by its name to edit...
Message 5 of 10
JamaL9722060
As per the screenshots below, the “block editor” icon on the “block” group initiates the “edit block definition” but not “block editor”Clip_415.jpgClip_416.jpg
Jamal Numan
Message 6 of 10
ВeekeeCZ
Pardon my ignorance, but how is it different? It's just a different label, both edit a block definition.
Sure, you need to hit OK to get into the Block Editor.
Message 7 of 10
JamaL9722060
Right. Pressing OK does initiate the “block editor” as per the screenshots below.
However, both approaches fails to initiate the “block editor” by directly right clicking the block inserted in a table the same way it works when the block is not inserted in a table
Jamal Numan
Message 8 of 10
RobDraw
You're welcome.
Rob
Message 9 of 10
ВeekeeCZ
If you do these edits often, you can use this LISP. Just pick a block when no table is active.
(defun c:TBEdit ( / e)
  (if (setq e (cadr (reverse (last (nentsel "Select block within a table: ")))))
    (command "_.bedit" (cdr (assoc 2 (entget e)))))
  (princ)
Message 10 of 10
JamaL9722060
Thank you for the help
best
Jamal
Jamal Numan
