AutoCAD 2023 - Drawing Versions Not working with OneDrive
ilawrenceYC9AX
Observer Observer
ilawrenceYC9AX
Observer
Observer
AutoCAD 2023 Help | "No Drawing Versions" shows for DWG History in AutoCAD | Autodesk
Running into linked issue above in AutoCAD 2023, I have tried all mentioned solutions, but nothing is working. was directed here by AutoCAD support for further resolution.
Anyone had this issue and resolved it?
paullimapa
did you try this one:
Turn off Files On-Demand: Right-click the OneDrive cloud icon in your Windows taskbar, open Settings, and turn off "Files On-Demand" (or select "Download all files"). This ensures the DWG file is fully downloaded locally for AutoCAD to read.
Paul Li
IT Specialist
@The Office
paullimapa
ilawrenceYC9AX
Observer
Observer
Made by mistake didn't mean for there to be 2 as the first one didn't initially appear so thought it didn't take.
ilawrenceYC9AX
Observer
Observer
I will try this and see thank you for your reply
pkomatlapalli
Hi @ilawrenceYC9AX ,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update.
If you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
Pavan Kumar | Community Manager
