I'm currently using ACAD 2022, previously I was using 2021, and a guy in my office uses 2020. When anyone in the office uses 2021 or newer we get this purple overlay when exporting the overlay. I don't have the option to go back to 2020 in my organization.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
I should also add that it does not look like this before exporting it.
you can change the colors you want for "No Difference"
In the dwg compare menu go to the sprocket and see what colors you have set
CADnoob
CADnoob
I use the compare command, everything looks perfectly normal. The colors are separated into existing versus different in the drawings. When I export that comparison, the entire drawing turns to one color as you can see in the attached drawing. The comparison color scheme has completely changed and you cannot see what is different between the drawings.
You can only adjust the colors when you are creating the compared overlays. It changes colors once I have exported it and there is no option to adjust the colors at that point.
Open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help: https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options/we...
I have the same issue. Feedback from Autodesk was that the issue was linked to a dimension object(s) in the drawing. Unfortunately I have dimension objects in every block because of dynamic feature so I have not found a viable solution.
I like to see a sample (2x DWG), can you share one - is it possible?
Sebastian
Sebastian
