AutoCAD Forum
AutoCAD 2022 Command Bar
7 REPLIES 7
Message 1 of 8
coffeejeanpaul
2607 Views, 7 Replies
Good day.
I found something annoying with the latest 2022 update.
It might just need to be a setting that needs to change, but I never had this before.
Hence I need to know the fix ^^.
So my command bar is usually full length of the drawing window, When errors pop up now or completed plots.
The window tends to show behind the command bar and I need to move the bar all the time(annoying).
See image attached if some one knows how to fix this in 2022 would be greatly appreciated.
7 REPLIES 7
Message 2 of 8
you can try this and see if helps. thanks
Message 3 of 8
imadHabash
in reply to: coffeejeanpaul
To avoid this matter ... I suggest to drag the command window to dock or undock as suggested in the previous post .
Imad Habash
Message 4 of 8
coffeejeanpaul
in reply to: imadHabash
Hi
One tends to dock the command bar always, all the time I dock it at least.
So I do not think it is the issue see images of 2022 and 2020 command bar.
it is like it is always moved to the front in 2022 -.-
Message 5 of 8
imadHabash
as you can see in below image it's still not docked !!
Imad Habash
Message 6 of 8
Your screenshots shows it differently, your command line is less wide than the graphic area.
Move it downwards until it is really docked (move the command line downwards until a rectangle appears on the bottom from left to right border, showing you that this would be a position for docking) 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 7 of 8
You know what good spot ^^
Message 8 of 8
coffeejeanpaul
Correct ! you passed the test
AutoCAD Inside the Factory
