Autocad 2021 Save File problem
Message 1 of 23
I have this problem with Autocad 2021
Please solve it.
Thank you
Ivano Venneri
Replies (22)
Message 21 of 23
nrz13
@cadffm
For what it's worth, I didn't do a reset and my save problem in 2020 went away. For the last several versions, I have imported my settings from the previous version. It's gotten much better over the years. It used to work pretty well, but not import everything over. So far in 2021 testing, it's imported everything except my double click actions.
I agree, not importing is the safest way, but it takes weeks of using the software before I get everything I customize sorted out.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 22 of 23
cadffm
It doesn't matter whether everything is set as desired.
It is annoying when not everything is imported, but nothing more.
The problem is that "impossible" behavior can occur.
I'm not talking about wrong settings that could be changed again,
but from completely impossible things (starting from a working standard version)
I used to find it good for people who don't know Acad well,
but in many years I have seen many cases and analyzed some of them in detail,
since then I would not recommend it to a beginner.
If you have structured your system well before, you need 5 minutes for the integration, actually only one minute.
Sebastian
Message 23 of 23
nrz13
I actually just tested this in AutoCAD 2021 and am having the same save problem.  I'm not going to reset all my settings to fix it because I probably won't use 2021 anyway (doesn't add anything I'd use or fix any bugs from 2020).  If I keep testing it, I'll try to pay attention to any other settings that might be changed and see if it solves the problem.
