Autocad 2021 Save File problem
Message 1 of 23
I have this problem with Autocad 2021
Please solve it.
Thank you
Ivano Venneri
Replies (22)
Message 2 of 23
ilia.borisov
What exactly is the problem??? You cant save file? Pop up message, crash, something...
Message 3 of 23
Save the file but when i close it acad ask me if you can save the file.
I save drawing in R2013 if i switch in R2018 solve the problem.
But i must save in R2013.
I try to switch R2013/R2018 and restart acad but not solve
6183adbe-ae2b-4daf-b258-4d6f05111140,640,590
Message 4 of 23
Alfred.NESWADBA
Well, in general saving your working file to an older format is not the recommended workflow.
Save your drawing file in the most current format, for AutoCAD 2021 this is DWG-2018 format ... does this work?
If you need to save something back to an older format, then use command _SAVEAS and create a copy of your working drawing (but do not overwrite your DWG-2018 file) ... does command _SAVEAS with DWG-2013 set as format work well?
If any of the above steps does not work ... what is the message you get?
Do you have the same issue with a new file and just one line in it?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 23
Save as… work fine with R2013 format, but when i try close the drawing acad ask me i want to save it
Step:
1-save as… (ok)
2-close drawing ask me save it.
why? I have already saved the drawing (step1)
No problem with acad2020 only with acad2021
Message 6 of 23
Alfred.NESWADBA
It asks because the drawing was converted to an old format for saving (so it has to downgrade some of the current objects to be compatible with 2013) and to make sure you can continue with 2021 it has to re-updated these objects (which means they are modified and so the drawing in this state is not saved.
Maybe if you have changed the default save format in AutoCAD 2020 (to save to DWG-2013 format by default) ... but this is far away from recommended. I would never work this way.
- alfred -
Alfred NESWADBA
Message 7 of 23
I also changed the default save format in Autocad 2021 to R2013.
its the same in Autocad 2020, same default format in 2020 and 2021
Message 8 of 23
cadffm
2021 AutoCAD, not a Toolset?
Start ACAD (Desktoplink)
Then test it with a fresh new file, use the standard 2021 template (or no template),
do not import other stuff, saveas dwg2013, close.....still asking?
With a new file and with my clean AutoCAD files, i can not reproduce this on my side.
My thoughts are the same as Alfreds.
Sebastian
Message 9 of 23
Sorry… where are fresch new file 2021?
I use my model and work in 2020 but have this problem with 2021
Message 10 of 23
cadffm
Start Acad2021, Command NEW, right of the [Open] Button is a tiny menu, use Without template - imperial (or metric, does no matter)
Saveas dwg2013.
Close
Still this message with this file?
Really AutoCAD, or a Toolset?
Sebastian
Message 11 of 23
Yes I still see this messages
No tool set.
Message 12 of 23
cadffm
Ok, if you don't save in DXF-Format, i don't know.
1. Would you please share this new created empty file with us?
   I will check the data for strange things.
2. After saveas dwg2013, close <<The message appears now>> make a Screenhot!
    Please, a screenshot of whole program windows incl. this message, thx.
Strange
Sebastian
Message 13 of 23
Message 14 of 23
cadffm
The only for me unusual things a can see
1. DWG
There are Rendersetting informations,  that's not the standard ootb for a standalone install of 2021.
2. Screencast (thank you, excellent choice to show what happen)
I see that the Screencast record UPDATETHUMBNAIL and VIEWBACKSTATUS,
in my Test Screencast i can not see that - but perhaps it is a Screencast setting i don't know,
but it looks strange for me!
Try it in Safemode please! Because we can see your profile is not ootb and you play with programming ;D
[Win]+[R]
Open: "C:\Program Files\Autodesk\AutoCAD 2021\acad.exe" /product ACAD /safemode
I don't know if this is a hint or not.
Please open your Acad in safemode
Sebastian
Message 15 of 23
nrz13
I had the same problem with AutoCAD 2020 when I first installed it.  The problem went away on its own, so I'm not sure what was causing it or how to resolve it, but yours is not an isolated incident.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 16 of 23
I try with safe mode but not solve it.
Yes my autocad 2020 is persanalized for my drawing and 2021 import the settings from autocad 2020.
Stange
Message 17 of 23
Alfred.NESWADBA
can't reproduce your situation while doing the exact same steps with the same setting for default file format DWG-2013.
Do you have any LISP to apps running on top of AutoCAD?
- alfred -
Alfred NESWADBA
Message 18 of 23
i solve it!
1) return to default settings
2) NOT import settings from acad2020
3) I redone all the settings one by one manually
A long job but it worked!
Thanks for your support.
(Don't close the discussion, let me test it for some time)
Message 19 of 23
cadffm
>"I try with safe mode but not solve it."
Ok, no Lisp or other 3.party stuff involved.
@nrz13 thx for information&link.
New Profile
Reset to default
Deinstall Reinstall
AND NEVER MIGRATE settings from older versions!
Sebastian
Message 20 of 23
cadffm
Oh, perfect! (didn't read your last post early enough)
Sebastian
