AutoCAD 2021 New Trim & Extend Command
I've just upgrade from AutoCAD 2018 to 2021 the new extend and trim doe not extend or trim lines, unless the is crossing the path of the lines your trying to extend or trim. AutoCAD 2018 just doesn't care where the line is, it just extend or trim from it.
I know that there is a Mode function in the command to go from quick to Standard. However standard is almost the same as the old way AutoCAD 2018, but it's not.  Does anyone know if there is away to put behavior back to way AutoCAD 2018 was working?
user181
Have you tried setting EDGEMODE to 1?
that works, thank you.
