AutoCAD 2021: Missing Main Tabs "Home, Insert, Annotate..."
The image below shows the opening screen when I open AutoCAD 2021 - English from its executable. First, I don't have a "Welcome" page or anything, but more importantly, I am missing the <Home, Insert, Annotate, Parametric,...> tabs next to Thermal like seen here: https://www.youtube.com/watch?v=mM2a3vsMXXk
Does anyone know why this is the case/how to fix it? I am not receiving any error messages upon opening the application either. It is making it very difficult to navigate the application and follow tutorials.
Thanks in advance.
imadHabash
Try MENUBAR (System Variable) = 1 . also you can follow solutions in this link  .
Imad Habash
Alfred.NESWADBA
Try to activate a different workspace (and then back to your default one) ... gear wheel like symbol in the status bar lower right.
If this fails you might have a defect cui, this can be solved starting command _CUI, then (in the upper left area) right-click the ACAD item and select first "Restore ACAD.CUIX" (then close the dialog with OK), if this did not help then try "Reset ACAD.CUIX"
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
