Announcements
AUTOCAD 2020 Layer dorp-down menu is slow (lags)
does anyone have the same issue as I do?  Since upgrading to 2020 (with all the latest updates currently version2020.1) When I click on the layer drop-down menu it lags, could take several seconds before the drop.  I doubt it's a hardware issue, cause I'm running a cpu: Intel I7-8700 ram:16G ssd:256 Graphinc card: Nvidia Quadro P620.  It was working fine before the upgrade.  I already tried with  the hardware acceleration turned off, didn't work.
Calques = Layers in french
Replies (12)
Thanks for the link...those 2 solutions didn't work for me.  I've tried to turn off hardware acceleration and delete filters...doesn't work.
johnyDFFXO
If you remove all the content and keep the layers is the issue still in place? Would you post such a dwg?
pendean
Community Legend
Community Legend
Is this a problem in ALL of your files or this one?
and where do you store your files and how are you connected to them?
cadmonkeys
i have this problem too, and it's with all my files.. tried everything noted above as well
Same
same here - version Q 104.0.0 AutoCAD 2020.1.2
archx15
I have a same problem here.. and still no solution for this problem..
pendean
Community Legend
Community Legend
You all need to be reporting this problem to Autodesk directly through here https://www.autodesk.com/company/contact-us/product-feedback
Submitted per that link. Thanks!
Seems to be pretty widespread. I haven't had to do much sorting lately, so hadn't noticed it. Bloody annoying.
user181
I had this problem and message 21 in this post fixed it for me.
archx15
Upgrade to AutoCAD 2021 or 2022 and solved my problems.
