AutoCAD Forum
AutoCAD 2020 Dimensions in Block: By-Layer vs. By-Block Bug
8 REPLIES 8
Message 1 of 9
nrz13
1131 Views, 8 Replies
In AutoCAD 2020, dimensions within a block that are assigned as "By Block" ignore this attribute and display as "By Layer" regardless.  I've attached a sample drawing as well as screenshots of the issue in 2020 vs. 2018 and earlier.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
8 REPLIES 8
Message 2 of 9
Alfred.NESWADBA
in reply to: nrz13
I can reproduce the display issue with AutoCAD 2019 and 2020.
However, I can't do that in new drawings with new objects.
Have you created this block with 2020 or with 2018 (or older)?
Can you recreate the issue by creating the drawing with AutoCAD 2020?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 9
nrz13
in reply to: Alfred.NESWADBA
I created this test block with AutoCAD 2020 using an existing blank drawing template from an older (unknown) version.  I also notice that I can create the block without issue if using a 2020 template (but I can't copy the block into a new template bug-free).  So, unfortunately, unless Autodesk fixes the issue, it looks like we'd have to recreate all of our templates and entire block library to not carry this bug forward, which is not a feasible solution.
Message 4 of 9
nrz13
in reply to: nrz13
After seeing another thread that said the 2020.1.2 update fixes this issue, I installed the update.  It appeared to fix the problem at first, but when the layer is locked it doesn't retain the correct visibility.
Message 5 of 9
cadffm
in reply to: nrz13
It works as expected in AutoCAD      2020.1.1
It works as expected in AutoCAD LT 2020.1.2
Sorry for the late edits..
@nrz13
expected = Dimensions ans rectang are completely RED,
please check your _vernum again ???
_vernum and ABOUT info is often the same, but not every time, so check _VERNUM and ABOUT informations.
Sebastian
Message 6 of 9
nrz13
in reply to: cadffm
@cadffm
So when you lock the "Test" layer, it doesn't change the color?
Message 7 of 9
cadffm
in reply to: nrz13
@nrz13  schrieb:
@cadffm
So when you lock the layer, it doesn't change the color?
LOL
I found the hidden secret: My LAYLOCKFADECTL is set to 0, your setting is higher 🤣
Start an BugReport, it is not the same error as in the other post, but near too.
Sebastian
Message 8 of 9
nrz13
in reply to: nrz13
This bug still persists in AutoCAD 2021 when the layer is locked.
Message 9 of 9
nrz13
in reply to: nrz13
This bug appears to be fixed in AutoCAD 2022.
AutoCAD Inside the Factory
