Autocad 2020, 3dconnexion problem
New computer with 2020 installed. Everything works fine except 3d connexion space pilot pro.
Pickfirst variable set to (1) but using buttons on space pilot I have to pick action first and object second. Using toolbar in Autocad works as expected. I have been in contact with 3d connexion but they are saying it is Autocad related because "they implemented support for our devices".
Anyone else having issues?
Replies (12)
S.Faris
make sure the belowprovided values  are set
PICKADD - 2
PICKFIRST - 1
QAFLAGS - 0
SALMANUL FARIS
ennujozlagam
you can try to refer to this LINK and see if helps. thanks
Thank you for your replies.
Variables are set as shown. Zoom and pan are not a problem. Pickfirst seems to be the only thing affected.
Alfred.NESWADBA
can you please show us how you have defined your 3d-mouse buttons?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
The two most used buttons are move & copy.
I have "move" programmed to the "F" button And "copy" programmed to the "ISO1" button.
Is this what you are asking?
pendean
Community Legend
Community Legend
We need you to drill down further on how those buttons are coded: that can be done by cancelling an active selection first them launching the command (your issue), or simply start and accept whatever is selected (what PICKFIRST allows if there is no cancel-selection action first).
I'm sorry, I don't know what you are asking. I programmed the buttons through the 3dconnexion menu.
Alfred.NESWADBA
I'm with @pendean , we need the details what is stored inside these buttons.
Can you please create a screenshot of the button configuration where you start the move command?
- alfred -
Alfred NESWADBA
I apologize again for not comprehending what you are asking.
If I select an object and then the copy or move icon in Autocad it comes up saying "specify base point or {displacement}"
If I select an object and then hit the space pilot button it comes up saying "select objects".
This is what I am seeing below the command line.
Thank you for your patience.
Gentlemen,
I was able to get it to work properly. In the 3dconnexion software under Autocad is a "legacy" folder in which you can choose commands to map to the buttons. Using the "move/open" and the "copy" from this folder the action is back to how it used to operate.
Thank you for your assistance.
Alfred.NESWADBA
An AutoCAD can be sent (from a menu) with
^C^C_MOVE   ... or just ... _MOVE
Which means in the first case ^C^C stands for press twice <ESC> and is the same as "kill any active command and then start new command _MOVE" ... this "kill active commands" also deselects any selected objects, and so the _MOVE command asks for objects.
And therefor we wanted to know what exactly is sent to the AutoCAD command-line from your 3D-mouse.
But as it's solved .... good you found a way 😉
Interesting would now be what happens when you are inside an active command in AutoCAD ...
- alfred -
Alfred NESWADBA
TimSkene4428
I have a space mouse compact that used to work several driver versions back, but no more. Now I have AutoCAD 2020, the buttons work but it gives only jerky orbit motion. The variables are set as noted.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
