AutoCAD 2019 hangs when trying to open a specific file. Loading Modeler DLLs....
I have a problem with a dwg file and all older versions and back ups of the same file.
When opening it gets as far as loading modeler dlls and then hangs with the wheel spinning. I have tied to open previous versions of this file and also .bak & .sv$ versions and the same happens to all of them. This is a big problem as it is a live drawing that is still being worked on. I have also tried opening these on other machines and it does the same thing and so i know its not an issue with my autoCAD software and so would not be resolved with a software reinstall or repair
Does anyone know a solution to this issue?
Is there a way to get autoCAD to skip loading the modeler dll's?
The drawing is a 2D drawing.
Thanks for any help received.
Problem drawing added
Valentin_CAD
Hello Sahunt,
Welcome to the AutoCAD forum.
I was able to download and open your file.
I did run an AUDIT and found two errors.
I suggest you AUDIT the file and ALL the references.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
I have attached the corrected file (AutoCAD 2018).
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Many thanks Valentine
Unfortunately I still have the same issue so that leads me to believe the problem is with out IT system rather than the file itself I will keep on trying to find a solution.
