Autocad 2019 Freeze
Autocad 2019 Freeze
Autocad 2019 Freeze
Hi all
We keep Having a problem with Autocad 2019 in the company as autocad 2019 freezes anytime something is copy pasted or anytime the ORTHO Funcion is used.
Anyone has any Advice how to tackle this.
Thank you
Alfred.NESWADBA
please first make sure that your AutoCAD is updated, command _ABOUT should show the version 2019.1.2
If that does not help then please try to change the value of TEMPOVERRIDES.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
lequangvinhbkhn
I have also suffered like that with cad 2017. And finally I decided to reuse cad 2007, still enough for me to use at work. >.< You can try reinstall cad 2019.
_______________________________ Architecture in Phuong Vinh Company, chuyen thiết kế nội thất Hải Phòng, thiết kế shop quần áoxây nhà trọn gói Hải Phòng
rkmcswain
Have you searched the knowledge base? This may be applicable:
Copy and paste in AutoCAD hangs for a long time or fails to work in AutoCAD
