AutoCAD 2019 File Path Problem, Any Help ?
Message 1 of 11
Case : I have AutoCAD 2019 In My System, But not in the C: Drive It is On Another Drive But when i try to open a random AutoCAD File it always show me a message that ACAD.EXE is not available in C: Drive , So I created a file and put the ACAD.EXE in that Specefic Path to help AutoCAD To work, but guess what , a new error Message  is now shown
Which says that
" The code execution cannot proceed because ac1st23.dll was not found, reinstalling the program may fix the problem"
And Google Search did not help in there, Any help here ?
Replies (10)
Message 2 of 11
Alfred.NESWADBA
That can't work, Windows is not a system for moving a program file to another folder and it will work.
Uninstall and reinstall the whole product. Make sure you have full admin permissions and antivirus is shut off during the installation and first initialization process.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 11
Then How to install it in another Drive and keep it works smoothly
Message 4 of 11
pendean
Community Legend
Community Legend
Message 5 of 11
" May " Was For a reason
i already did so many times , but didn`t work out for me
Message 6 of 11
Alfred.NESWADBA
I hope you are thinking a built in harddisk, not an USB drive 😉
First run a clean uninstall process described >>>here<<<
Then download the installation media from your subscription center (https://manage.autodesk.com)
..and start the downloaded EXE with right click ==> "start as administrator"
- alfred -
Alfred NESWADBA
Message 7 of 11
Here is how to works to open a file
I have First to open AutoCAD from the ACAD.EXE icon or The Shortcut in the Desktop , then open my file
it seems like the Autocad can not locate the File Path when trying to open the file path directly
Message 8 of 11
LOL , For sure it is a Built in hard drive not the windows C: drive
Message 10 of 11
I Had to clean all Autocad data and the registry data and reinstall it , it works fine now ... Thank you it worked this time
Message 11 of 11
Alfred.NESWADBA
>> it works fine now
Glad to hear that!
Have a great day, - alfred -
Alfred NESWADBA
